..............I need a set of new heads for a 340 build......stock 1970 specs except for a 270H comp magnum cam....LD340 intake...using stock ex manifolds......whats the best bang for the buck..........thanks....kim.......
By the time you get a stock set of heads up and going, you could've bought a set of aftermarket heads for cheaper (this was the case for when it came to my x heads vs my eddy heads).
...............Thats y i'm looking.............kim.......
.............I'm looking for something compatiable with all the stock stuff............kim....
Neither the RHS website nor Summit lists any Mopar head applications
Here's the specs if you want to read them. I think you have to buy them from Indy now.
http://www.racingheadservice.com/whatsnew/files/rhsindy360xheads.pdf
For my 360 Magnum build I narrowed it down to RHS or EQ, not sure which yet. I ruled out Eddy based on many comments that they should be gone over before install (more $$) due to poor quality assembly, and because aluminum should have more compression to get the same performance (more $$).
