moffetkustoms
Hey everyone! Have a 73 225 that I converted to the HEI swap. Have gone through the threads as directed by SSDan and others and still fighting a no start issue!!! Hooked both the ignition run wire and the ignition start wire from the ballast resistor together and have them triggering the relay for coil. Hot wire directly from battery to relay. Ground wire directly to battery from module/coil/relay bracket as well as the bracket grounds. Have installed a new distributor and replaced the ecu module a couple of times. Have even tried to find someone to tell me how to Ohms check the module with no success. I'm really missing my seat time in the Scamp. Any Suggestion??????????
