bamacuda
I am having a divider board made with a cnc at a local school. If there is interest, I will have several made for sale ( I am thinking $75ish.) It will be high quality plywood with highly accurate reverse engineered cnc cuts/routing/holes made to insure that it is a perfect fit. I do have some questions that I posted in another thread that I need help with the answers so that I can make them more accurately. They are:
1) Did all of them have the textured backside?
1a) Were all of the backsides black?
1b) Was this a fabric glued/sprayed on like flocking?
2) Did all of them have the rubber bumpers?
3) Did some have the latches painted black?
4) Did all Formula S models have the routed relief for the larger blue streak spare?
5) Which ones had the extended end on the divider board?
I have three boards and each is different. One of them may be homemade, the other two are original,one formula s with a routed portion, the other NO rubber bumpers (or screw holes) and all three came out of 65's.
Please help!:cheers:
