Oh, and if you buy it, do whatever you want. Nobody has any say in your choices. They may not like it, but that's all.
... OK, chevy engine BAD, $2500 GOOD.
Talked to local auto recycler he called it a hot rod package 6.4 liter motor tranny harness 7500 $$Later model magnum motors are cheap and easy to build horsepower....Other wise go buy a Nova...
15:000 $ wow and no tranny yet I want your jobHellcat motors are coming down in price.
Complete Hellcat 6.2 Engine - Mopar (68303089AA) | EastcoastMoparts
15:000 $ wow and no tranny yet I want your job![]()
If you're making a drag car, why not buy something not so pristine and let this go to a daily driver type buyer. Hell, you'll likely end back halfing, tubbing, opening wheel wells, frame connecting, tubular k-member etc. This sounds like a nice made for driving car.
Just an opinion.
What are your goals with this car? How fast are you trying to go? Is there a specific class you want to run? Giving some info on your plans might help us give you a better answer.
No, I would never back half this car, frame strengthening probably.
Tub maybe and only if necessary. Would NEVER cut the fenders or take away from the stock look of the body. Its nauseating to see a car like this w/the fenders cut out to fit a drag slick.
I didn't know there was this much of a following for the 6 cyl cars though.
my last ls was setup for pure drag duty and ran 9s. For this car, not 100% sure yet, but I'm thinking a very stock looking body for sure on outside, with a bullet proof drive train (ie at least a strong setup) I could drag race w/slicks. This car would also be streetable (local use). turbo not out of the question to ease making power.
And you guys call the E-Body guys a bunch of elitist snobs...
Look at 440 source gives you a good idea.Yeah, ok thanks for spending my $. Now whats a well prepped 426 or 440 run? $20k?
This is absolutely correct. When you go to sell this car, and you will, no one will buy it.ad states he has a 400 for cheap, buy the whole package, build the 400 ($4,000) and burn tires till your bored with it. Resale is going to be way easier with a mopar engine in it. IF you put a chevy in it your going to find it almost impossible to get rid of later and have to give it away. So your options are spend money now to have a killer car (mopar engine) or build it the way you described and lose money later. Math can be tough sometimes, what to do, What to do?
I would respectfully disagreeim probably in the minority here, but if you're not putting a small block mopar in there, i'd rather see the LS then the modern "hemi"
if you're going with something that doesnt belong (and the modern "hemi" does NOT belong in a classic mopar) you might as well go with the most popular (across the board) engine, especially, if it is one that makes the most power the cheapest
in fact, i dont mind what you do, as long as you dont cobble it together (and since the OP is planning on racing it, i am going to assume he is planning on making it past tech inspection) and dont put in a farm engine
[/flamesuit on]
Still can be fixed, jerk the LS out, change out K frame if butchered. Re engine it w proper MoPar motorvation.
