HELP! Need Steering Knuckle 66 Dart
bshawzzd
Member
Can anyone help?
I need a new or used steering knuckle for my 66 Dart with P/S
If you don't have one - can you tell me where I might try and find one?
Bruce Shaw 215 657 2377
Do you need a pitman arm or a lower ball joint that the tie rod end attaches to?
I did not intentionally mean to be rude
I am having trouble posting and using this website
ok well first did you get the part/problem figured out?
second just post under the web section for help using the site!
I think we still need to know if you just need a spindle or something else? and if your car is 9" drum brake, 10" drum brake, or disc brake, and which side you need?
