I have a 73 Duster with a 360. When I first built this car 2 years ago I had terrible problems with the fuel system. I was running an 1806 Edlebrock carb, Carter mechanical pump regulated to 5.5 psi, acid dipped tank, new sending unit, new 3/8 fuel line, everything new. At idle I could watch the filter dry out, psi drop to 3 then come back up and the filter would fill back up. It would do this off and on along with cutting out at WOT. I pulled apart the pump and found some plastic stuck in one valve, removed it fixed problem until today, the exact same thing is happening with the exact same setup. I already pulled and checked the pump and all connections for leaks, I also removed the gas cap with no change, and I checked my N/S for fun. So, in closing, sorry for the long post but I am completely out of ideas. If anyone knows or has an idea please feel free. Thanks in advance.
