That is a very old cam. More recent cams are rarely ground with 114 LSA, including Crane cams. 114 is a loser. After D. Vizard tested 19000+ cams for Crane, the cams in later Crane catalogs were ground on tighter LSAs.
Hyd lifter cams.
In the 1984 Crane catalog, there are 13 cams listed, 6 are on 114 LSA. One is on 106 LSA
In the 2010 catalog, there are 47 cams listed. 7 are on 114 LSA, 13 on 106 LSA & 1 on 104 LSA. I used the SB Chev section because there are more cams & gives a better representation of the numbers involved.
Now people will be chiming in saying how well their 114 LSA cam performed. Compared to WHAT??
Below you will see a comparison of three cams, identical except for LSA.
The 110 LSA made an extra 5 peak hp. But this cam was 24 ft lbs down through the average compared to the 106 LSA cam.
Hyd lifter cams.
