- Joined
- Mar 6, 2008
- Messages
- 1,408
- Reaction score
- 1,135
See what happens with 18 degrees of timing at 2500 rpm.
That is a handy piece of information right there.holes drilled in the throttle blades are unnecessary
I intended to use one, but for now the port is plugged to rule that out as a factor.This was my next suggestion. Drop the timing at 2500 and see the effect. I’m now thinking it’s a bypass air problem.
@gumper is there a pcv valve on the engine?
I bumped it down at 15 at one point. All it did was make the engine run rough.See what happens with 18 degrees of timing at 2500 rpm.
Going to throw a piece of tape over the holes just to experiment next time I start it.That is a handy piece of information right there.
Awesome!My engine is only 15 years old so it’s not old enough to smoke
Check your grounds. Maybe the electrical system is grounding through the cable.As a bonus my shifter cable apparently has melted despite using a DEI fire sleeve and header wrap to keep the heat off it.
What happened when you pulled timing?I soldered the holes closed and still no good. Both the primary and secondary idle screws are backed out as far as they can go. I’ve opened the idle screws about 5 turns. The lowest I can get the idle is 1800. I put air to the intake with the carb covered and sealed and sprayed everything with soapy water. Cannot find any leaks. The only things left is put RTV around the intake ports if the orings aren’t sealing, and change carbs.
As a bonus my shifter cable apparently has melted despite using a DEI fire sleeve and header wrap to keep the heat off it. This Hemi thing has been a nightmare for me.
Engine ran rough but stayed at the higher rpm.What happened when you pulled timing?
Interesting, how would it “control” the engine? It has no ability to manipulate the throttle body, and you said your timing is at ~22 degrees?Engine ran rough but stayed at the higher rpm.
I do think I found the issue. The MSD Hemi 6 box uses the 32 tooth reluctor wheel which I did put on the crank. It’s a 2009+ engine though, so it had the 58 tooth wheel plus the sensor for the 58. I didn’t change the sensor to the older 32 tooth style. Going to change that tonight since it’s pretty much identical on the outside and see what happens. That’d make sense that it thinks the engine is spinning twice as fast as it actually is.
It is set at 15-25 depending on the RPM. I’m not 100% sure this is it yet, but it is as good a theory as any right now.Interesting, how would it “control” the engine? It has no ability to manipulate the throttle body, and you said your timing is at ~22 degrees?
