I made 2 runs. Each run was filmed from outside an a camera was inside.
The first run I peddle it in the air an rode the brake to bring it back down. It went 10.16 137 with a 1.44 60.
The second run is what hurt it. It went so high it drug the chute pack. That may have been what saved it from flipping over. It only had one of the rear tires on the ground.
I never had a chance to lift or hit the brakes it moved to quick. It lost traction an hit the ground.
The last 2 clips are from inside the car. You will be able to tell what runs they are from.
This track was awsome! This was only a 100 shot!
Remember this is a leaf spring car an I leave off a hard idle.
