In the photos i dont see the thick base gasket. If this is the case,that is your problem.
Then your fast idle cam is NOT free to rotate and you need to address that first.It stays in the position where it is in the photo
I disagree ( but I see where you were going), I do not have the thick base gasket and my car starts and runs fine even in COLD Colorado weather. two pumps on the gas after a week of sitting and it starts right up and idles fine at fast idle. then after a few minutes everything warms up and it idles at normal idle.In the photos i dont see the thick base gasket. If this is the case,that is your problem.
looking at both carbs in post #6 and the carb in post #11 there is a huge difference in the amount the idle screws are turned. Mine (post #6) works great OP doesn't. Also OP stated in post #15 that is fast idle cam does not return to full clockwise on its own which is what OP was eluding to in his original posts.so the curb-idle screw,to me, looks about right.
Yours looks right for an early-Alooking at both carbs in post #6 and the carb in post #11 there is a huge difference in the amount the idle screws are turned. Mine (post #6) works great OP doesn't. Also OP stated in post #15 that is fast idle cam does not return to full clockwise on its own which is what OP was eluding to in his original posts.
