MOPARJ
What can I upgrade now?
Do you have those 318 heads still on there. Must have, that helps too. With 360 heads it could hit 6500 rpms with fresh valve springs.
With the 318 heads you can run a bigger cam, with 360 heads and those larger ports, its best to stay a little on the small size.
You could always try 360 heads later on, just make sure you get them milled to around 63cc chambers to keep your compression up. I have the newer 360 high swirl heads with a 2.02 intake valve. It was a big help everywhere but I am running 3.91 with a 2.74 1st gear auto trans.
They are stock 1.78/1.50 valved 318 heads, which helps with port velocity. I thought about trying a set of 302s, but have not found any to work on.
I think the addtion of 3.55s eventually will help, as this thing still only turns 2700 rpm at 65 mph, due to the large 235/70/15s on the rear, maybe they are 245s, I cant remember.This is 3.21 gearing too, so if I could turn it at 3,000 rpm with the 3.55s, Id be stoked.
