Mopar to ya
I know this has been beaten to death, but my carb started dumping fuel this morning. I know just enough about carbs to be dangerous. I have often wondered what the jets sizes were, since this is the carb it was dyno'd with and I'm sure it was set up for max power, not street driving / power. I took it apart and it looks like the numbers are 86 on the primary and 75 on the secondary side. I see no numbers on the power valve. Since I have it apart, I'd like to play with it a bit. Any advice on jet sizing? There are different power valves, too, aren't there? Also, when setting the floats, I assume you adjust them until fuel just runs out the side drain plug? Here is what I run. Sorry it's long, but it's simpler to copy and paste. Any help would be MUCH appreciated!
Here is what I have:
1992 magnum block
scat 4" stroke crank
Scat forged i-beam rods
Diamond flat top pistons (11.8:1 compression)
total seal rings
Engine Pro main, rod, Cam bearings
Fluid damper
Cloyes double roller timing set
Cometic head gaskets
Edelbrock performer rpm heads (gasket matched w/ light porting)
Smith Bros pushrods
Comp 1.5 ratio shaft mount billet roller rockers
comp hydraulic roller lifters
Comp Cam
242/248 Dur@ .050, .3660/.3630 lift @ .050, 112° lobe sep. 549/544 gross valve lift
Comp valve springs, retainers, keepers, locators
ARP head studs
ARP bolts used throughout
melling hv oil pump
Edelbrock RPM Air Gap intake
MSD Pro Billet distributor
bronze dist gear
Holley 750dp mech secondary manual choke
Mopar MSD 6 Ignition box
Blaster2 Coil
1992 magnum block
total seal rings
Fluid damper
Smith Bros pushrods
Comp Cam
ARP head studs
melling hv oil pump
bronze dist gear
Blaster2 Coil
