JAG
How much more horsepower do you think is created when a stock 273 is changed to a Edelbrock LD4B manifold and a 500cfm carb. Hedman headers and dual SS exhaust?
I'll be generous and guess 6.
It was a factory 2bbl rated at 190hp/4400, 260ft-lb/2000Which one are you starting with? Factory 2 bbl or factory 4 bbl
Okay thanks, the performance now seems like a lot more than 10hp. I will consider further modifications in the future.If you are a tuner you might, maybe, pick up 10 hp...........stock camshaft for a 190hp 273 is not going to pull a lot of air; at this point in it's; the engine; life, the springs are kinda soft, so it will pull even less..........not to be a downer, just a realist, a 4 bbl intake, carburetor, and headers do not guarantee lots of HP, just the possibility.....to get everything out of what you have, you need more camshaft and compression.
Thanks, sounds reasonable30hp tuned well.
Your in the 220/230hp area.
180 horseIt was a factory 2bbl rated at 190hp/4400, 260ft-lb/2000
I do feel the difference, and the exhaust sound is awesome. Takes me back to the sixties.You'll feel the difference.
Just the sound of the secondaries is worth it.
Where did you get that 190HP... Canadian HP...like the Canadian Dollar?It was a factory 2bbl rated at 190hp/4400, 260ft-lb/2000
180 or 190 depends on which site you google. Doesn't matter to me. Just wanted to know what the hp increase would be with the mods.Where did you get that 190HP... Canadian HP...like the Canadian Dollar?
SAE Gross Horsepower & Torque:
Std 273
180 @ 4200 RPM & 260 Ft/lbs @ 1600 RPM
273 Commando
235 @ 5200 RPM & 280 Ft/Lbs @ 4000 RPM
D/Stock 273
275 @ 6000 RPM & 295 Ft/Lbs @ 4400 RPM
