MopaR&D
Nerd Member
Radiator/fan setup looks good to me... I'd try a smaller water pump pulley, the one you have looks like the bigger non-A/C one. Did you get a chance to check the total timing?
Just curious, what cam is in your engine? Also I noticed you have EFI, what kind of system is it? Should be pretty easy to get some A/F readings if it's closed-loop.
And the other guys were asking, what's the temperature outside going by the weather report when you're at the dunes?
