House Explosion
As a "utility" worker, Ive seen some unsafe stuff too. How about a pair of jumper cables hangin down off the mains? I was looking for a telco terminal in an apartment and ran across it in the 120 square foot laundry room that the manager had 'converted' into a STUDIO APT! The water line stubs were still coming out the walls and there was a makeshift toilet in the corner behind a curtain, converted sink and a hot plate! F this....called code enforcement and went back the next week: Cleared out and a new manager on site. I understand housing the poor, but not like that. Seen a T before the new remote read gas meter on a few places....If the guy who reads it never sees it, whats to stop intercepting the gas before the meter now?
When I was taking the "gas mechanic" course in Spokane years ago, they showed us a defective gas meter riser, and the instructor told us a story. There had been a bunch of those, with I guess corrosion problems. The gas company was going around routinely replacing them as they had time and opportunity. They did not notify the resident, they just replaced them. One time they dug one up and it had been tapped into before the meter--underground---and the guy who lived there WORKED FOR THE gas / power company. He narrowly missed going to jail. They totaled up a "fat" estimate of what all they figured he had got for free, fired him, leaving his nice retirement package behind, and turned off his power and gas. He had to move to an area of town served by an alternate power company, and do without gas
In about that same area of time, the senior guy I worked with and I went out to service a 3 phase unit on an old rooftop, above a photo developing/ editing outfit. Usually, you can just pull the roof disconnect. This one brought power up from the roof, through a conduit in the bottom of the unit, and three hots went up right across the blower, right behind the access door, and into a disconnect mounted on top of the unit. The three return hots came back down the same way, and went into the control box. So there were 6 hot 3 phase wires in there.
We could NOT find the breaker. I was all for throwing a wrench across the disconnect and closing the switch, but my partner did not want that. We actually pulled the hots one at a time with insulated fuse pullers, taped them off, and carefully pulled them out of the way
I found out a couple years later, after a minor problem in the building, that someone had illegally "t tapped" a much larger conductor in a cable run
How do I build a house to exclude the possibility of something like this? My house is under construction now, and that would be nice to know what additional measures of protection I can apply. Of course, I have hired some gas professionals, but it’s always better to know something yourself. Maybe you can tell me some tips or suggest some resources I can read and get informed? I really don’t want something like this to happen in the house I build. So, it’s always better safe than sorry.
Leak detection
So they added T's to steal NG?
I think the city should have the gas company inspectors check at least once every year. Then this may have been preventable. But then again we don’t know if it was something the home owner did. Kim
I went to a pool party and the pool was about 90F. I asked how much it cost hom to heat this thing and he said it's free and showed me the straight pipe he installed where the meter used to be. He said he'll Install the meter back on Monday
Just a spray bottle with a little soapy water to find pipe leaks. Get a detector is you have propane, just like an RV or camper. Propane is heavier than air, it can build up from the floor. That's why they're at low spots on RV's. Natural gas is lighter than air, it will rise. Check your draft on your water heater if it's the natural draft type with the hood at the top center - smoulder a match or bit of cardboard near the opening - it should draw in and out the flue.
Well it "ain't that simple."
There has been cases when leaks quite some distance from the house has leaked along piping underground, and found it's way into a building through the piping entrance into the house.
Also, indoor piping is VERY low pressure, which in some ways makes it more dangerous. That is, a pipe cracked due to stress, earthquake, etc, may not leak right away, or may not leak all the time. Same is true for connections or valve packing. Normal "in building" pressure in the states is "quarter pound" AKA .25psi. Some commercial buildings run "half pound" and very large facilities can run "other than." .25psi is normally measured in the industry in "water column" that is 7" water column. A toy balloon likely generates more pressure
Also, some people are insensitive to the smell chemical added, and like any smell, if you start to experience the smell and don't recognize it, you become insensitive over time, and it can stronger and you not realize that.
None of these leaks of course "happen" yearly or on schedule.
I don't know what the answer is. Have your system serviced by a pro that you trust, and I used to do that "in a previous life." Without installing an explosive gases alarm/ monitor---which last I knew were quite expensive, your best defense is to "pay attention." If you think you smell something, you probably do. If you smell something and can't run it down, be INSISTENT. That has been a prelude to several explosions---"customer reported smell but cause could not be found" or some such
The only other solution I can think of, is to build your house/ building in such a way that the furnace/ piping is OUT of the house---a well ventilated "doghouse" on the side/ rear of the building.
These tragedies are like airplane crashes---they are sensational, but don't happen very often.
And often, you don't hear the details. Sometimes, possibly many times, these accidents are caused by "**** people do." I made one customer VERY angry one time, went down to do some sort of service, don't remember. But I DO remember---they had just moved in, and had an LPG dryer from their other house, and there in the basement was an LPG bottle hooked to the dryer.
WHY IS THAT DANGEROUS? Because LPG is heavier than air, and REGULATORS can leak. Gas regulators are required to have a safety vent in case the diaphragm ruptures, and either vented outdoors or in the case of a furnace or other appliance, be vented in such a way that the leak is vented into the combustion chamber via the draft air path.
Customers sometimes do all kinds of unadvisable stuff. Older equipment can be a problem. In the 80's--90's when I worked in the field, there were still a LOT of gas valve/ gas valve trains that did not have "100% shut off" safeties, meaning if the fire went out, the main burner valve shut down, but the PILOT light still sat there and leaked.........and that was perfectly acceptable back then.
I can still remember a service call early on a Monday morning. This was an older house downtown, been converted into legal? real estate? offices. The furnace was a "gravity convection" meaning no blower. Huge old thing down there with huge ductwork. It was overheating. The controls were all old--antique, really. The main gas valve---the one controlled by the thermostat, had failed---OPEN, and the stat had no control. Neither did the "high temp limit" as the valve was mechanically stuck, and out of the loop electrically. This was an INCREDIBLY simple system, and old----the old, separate "valve train." Main manual shutoff....the pilot gas valve, the pilot safety, and the "main operator" huge, motor powered.
Only reason it did not burn down, is the house was so old and leaky, and it was VERY cold weather, so it had the house up to maybe 80-85 and they finally opened the windows.
If it had been say, 35F outdoors instead of 3 POINT 5F it probably would have caught fire.
