How do I decipher the engine code on my 360/727
Chryslerkid
Berkeley
Hey guys does anyone have the run down on reading engine block and head codes as well as transmission codes? Thanks.
:banghead::oops::blob::glasses7:
FYI I have a 360/727 drivetrain but want to verify the year of production and specifications of that year motor. Thanks
The engine date of production is cast onto the passenger side. Attached is a pic of my 360 block with a circle around the date. As for the trans. you need to look on the drivers side right above the pan rail. There'll be a set of #'s starting out with PK then a 7 digit # following. Here's a link to a website with those #'s so you can see what year it is
[ame]http://mymopar.com/downloads/transguide.pdf[/ame]
yea that I knew... however we tucked the engine in the corner of the garage, and I really didnt feel like pulling it back out to check out the passenger side.. plus its pretty grimy and in need of some degreasing.. lol.. I was more interested in the numbers stamped in the block in the front (right below the drivers side head) trying to figure out what those meant
Gotcha
Engine:
on small blocks there is also engine assy factory, size, date assembled, etc info on the left front cyl bank. 68 up on right oil pan rail is year, car factory, and last 6 of VIN of origin.
68 up on the pan rail of the trans (auto) there are a string of numbers to identify similar to engine. On manuals on the right side towards there is about a 1/2 x 3" rise with information on it with similar info.
