How important is 1psi of fuel pressure?
Except when it doesn't.
It depends on the type of mechanical pump, and also depends on the type of regulator if one is used.
Oh wait. I already posted that. Oh well. redundent post.
Easy way to show this is, take a garden hose, no nozzle, just free flowing. Then take same hose, put a nozzle on it. Which flows more fluid and which has higher back pressure...
That’s not 1psi. That’s upwards of 60-80psi.
SN: I ended up leaving it and it works fine.
Tim,
Post #29. Do you mean that adding the nozzle increases flow? If so, that is incorrect.
I was takin for granted no regulator. Anyway, that said. 1PSI is pretty important if your gauge reads 0. LOL
Tim,
Geoff, Do you want to reread Tim's post and delete yours?
Two scenarios and the question was which one has higher pressure and which one has higher flow?
How in the world could you think that Tim meant that one with higher pressure is the free flowing hose?
Mattax,
No I do not want to delete my post. I asked a valid question & I asked it politely.....
If somebody asks a rhetorical question, maybe they should answer them so there is no confusion about what was meant...
Mattax,
The one withe the nozzle will have more pressure everything else being equal..
Tim,
Are you saying in post #29 that the higher pressure [ nozzle fitted ] would fill a container quicker than the open hose would?
