how to have the car to install Sub frame connectors
Update that gap at the rear is now only 1/4 of an inch. I cant get it any closer.
If you use a straight section for the connector you will have that gap.
I sliced the corners and bent that bottom peice up to the frame and welded it up, then ground the leftover corners down to match.
