Don't know if any of you remember my original post ( http://www.forabodiesonly.com/mopar/showthread.php?t=132400 ) but I finally fixed my cooling problem. I was at the point of buying an aluminum radiator but decided to try a couple more things and they worked. I still have the stock two row 22" radiator. Already had the 8 blade waterpump, didn't keep it cool. Put on a fan shroud, didn't help much. Went to 18" 7 blade factory clutch fan, didn't help. Put on a 18" 7 blade flex fan, didn't make any difference. Today I put the spring in the lower radiator hose and put a high flow thermostat in it and it never got over 185*. I guess the thermostat let the pump do what it needed to, move the water faster through the cooling system. Drove it about 10 miles and had to idle in downtown traffic, got on it a couple times went home and let it idle about 10 minutes in the driveway. It would go to 185* and you could tell when the thermostat opened because it would immediatly drop down under 180*. Thanks for the help everyone.
