Hello guys. I have a 1973 roadrunner 340 and was looking to clean up some of the ignition components. My first question regards that little vacuum advance module which is circled on the right in one of my pics. The top hose goes to the vacuum advance on the distributor and the bottom hose goes to the nipple for the vacuum advance on the carb. My first questions are what does this little module do and can it be removed and I just run a hose from the carb to the vacuum advance on the distributor? In the second pic I show where it is hooked up on the carb. Is that in the right spot for the vacuum advance? Now, in the first pic, there is a little band to the left of the vacuum advance module and it is connected to nothing. Can I get rid of that? Thanks in advance!!
