63 B or c body B block exhaust manifolds on an A body with a 383?
Will they fit
Will they fit
You got some lungs there!but I was going to open the back door, & yell for You to get the hell outta there!!!!
Is there a driver's side manifold that WILL fit?
An offset master cylinder and a tin heat shield would go a long way here, Jim.Best fit is '68-73 HP, but will need mods to the steering column. I have mine shaved around .040" for a little better clearance, but I haven't reinstalled the column because I'm not sure I don't have a small leak and I've been working on the AC install.
Completely unnecessary, but I did pick up the offset bracket, just don't have the pushrod. We put 35,000 miles on this same setup between my old Dart and my son's Dart with ZERO brake failures.An offset master cylinder and a tin heat shield would go a long way here, Jim.
But it looks great!
Thank you for clarifying this...Completely unnecessary, but I did pick up the offset bracket, just don't have the pushrod. We put 35,000 miles on this same setup between my old Dart and my son's Dart with ZERO brake failures.
