mrbadwrench
it ideas on kits to use i was thinking about using tci pro overhaul kit. is there a cheaper one or a good kit to use.
You didn't say how you will primarily be using the car. I set the Demon up as a street car and put in what TransGo called its RV shift kit back when I rebuild the 904. It speeds up shifts without objectionable hardness. It looks like this is called the TF1 re-programming kit. For my intended use of the car, it works very well IMO.
