Installing FBO Advance Plate ...help
With your Mallory style type distributer, it’s easy with the two adjustment screws, you don’t need the kit to do the recurve. I just use a protractor and a zip tie. You will get a true Measurement. Redneck Re-curve
I started this morning, following the instruction on his web site but got stuck. I can not find how to get the top shaft off. His instructions says there is a clip or screw to remove....can not find either one.
This is a MP electronic advance distributor made by Mallory for MP
Mopar Distributor Tuning J685S
I like it
Set up your distributor without a distributor machine - nice.
I am confident that this method is not near as precise, non the less it will get you there with some trial and error.
Distributor P/N?
but need kit to adjust it.....well...I guess i thought his plate would fit any MP distributor ....i guess not
that kit is just plastic wedges isn't it? just need to know what the one you want measures and it should be easy to go from there.
That is what I did.....kit give you an metric allen wrench...the screws take a torque set head,
