intercooler size, help
mcat
cincinnati ohio 45251
i am limited on space,
i can fit
A- a 27x7x3.5
or
B- a 27x12x2.5
what is the better choice?
i am leaning toward the thicker 7 inch as to not block so much of the radiator
10-15si max..maybee20
the rule of thumb for intercoolers is that you want more tubes for better efficiency vs longer/wider tubes. i would run B. or even try and find a 27x12x3.5. what kinda car is it going in?
- Bar & Plate Aluminum Intercooler
- Overall Size: 32"x12.5"x3.5"
- Core Size: 20"x12.5"x3.5"
- 2.5" Inlet & Outlet
- 3.5" Thickness Core
Here's this one from CXRACING, these are not crap intercoolers had one on my neon srt4 held 30psi of boost, very good quality work and pieces, he gets the same cores as the same big names.
