Ok, now the BJ/steering arm looks ok. But the angle going back to the drag link looks a bit steep, even if the suspension is at full droop.Is it possible that the pitman arm is wrong? Is the drag-link level from side to side?
-If for some reason you have cranked the T-bars up, or the engine is not in the car, that would account for the steep angle.
Heres what I would do; A) center the steering wheel and anchor it there, and B)shorten up the tierod assy until the wheel is pointing more or less straight ahead, and C) put the car on the ground at correct ride height, and re-adjust the tierod to put the wheel again straight ahead, and D) snap a new picture, more or less parallel to the floor, and include a portion of the sidewall for reference, and a second pic of the pitman arm, including a short section of the drag link. I understand that taking those pics might be difficult, so if you have some blocks maybe 6 or 8 inches high, you could put one under each wheel and snap a pic of that. The important thing is to have the car at or near the correct ride height.
-I usually reference from the lowest point of the K to what ever surface the wheels are on with full weight of the front end on them. This dimension, with 24inch tires usually falls around 6 inches +/- a half inch.
-When you are finished adjusting the tierod assy, both ends should have about the same number of threads showing.
-Maybe try to get a pic from the back, like the one in post#17; either side(drivers preferred). It shows a lot of reference points.
