straightlinespeed
Sometimes I pretend to be normal
Hey guys and gals,
I rebuilt my suspension over the winter. I used the Moog offset bushings. I installed them using the diagram below. Front arrows pointing to the ball joint, Rear pointing to the engine.
I was shooting for the typical performance specs in this chart.
I was watching them and assisting the whole time and this is the best they could get, using a laser alignment.
Drivers side
Camber -0.4*
Caster 5.4*
Toe .13*
Passengers side
Camber 0.2*
Caster 5.1*
Toe .12*
My UCA's are all the way out in the front, and all the way back in the rear. If they moved the cam for the fronts towards the outside of the car in the camber when way positive.
If they moved the cam's for the rear the caster went higher, at one point it was 6.7*. So we just adjusted the Toe so it wouldnt eat the tires up for the time being. Im also wondering if the cam position matters when I put them in.. Im assuming not, but just curious? What is going on?
Drivers side
Camber -0.4*
Caster 5.4*
Toe .13*
Passengers side
Camber 0.2*
Caster 5.1*
Toe .12*
