The example you gave had work to the heads more Cr different intake same gears and stall each one of those time could add up to make a difference.
It's hard to do apples to apples comparison cause a 360 vs 408 all parts have to be tailored to each of them, port of the heads cam timing gears stall intake exhaust etc...
If a 408 is making more power than a similar built 360 than that means the 408 has a higher VE% so the parts being used is more in lined with what a 408 needs vs a 360.
the extra compression helps, no doubt
All the heads got was 2.05 intakes and fresh valve job, as I said, maybe 20 horse.
The excellerator is so small not sure it is any better than the airgap it .replaced.
Heads only flow to 550, have good low lift numbers, peak at 272@550
They are too small for the stroker, were not for the 360.
Of note, car picked up nearly 7 mph to the 1/8, only 4.5 in the 1/4.
Ran 6.78 in 1/8, 10.77 in 1/4, shows head is too small... but, still picked up 1/2 second in 1/4,picked up .44 in 1/8th.
1/4 numbers are like 10.60 ish car if you convert numbers.
Also reusing 1 5/8 headers.
Guess what I am saying is, 418 isn’t nearly as optimized as 360 was, still lots faster, especially in the 1/8... from 7.19 Best to 6.78. That’s a bunch
