PhillH
So the day finally came when I could take the 360 Scamp out for it's maiden voyage, first engine I've ever rebuilt, very happy!
I already had it initially broke in but not driven except around the block a few times to test driveline. Everything went really well but I just want some advice from veterans. I rebuilt the Edelbrock 625 and have not tuned it yet, but followed directions.
1. The timing is at about 16/17 idle with vacuum plugged, but seems to go almost 50 degrees around 2500 rpms, this seems high to me. Also it runs great with no stalling or hard to turn over but I have to hold the throttle to the floor and crank about 4 or 5 seconds before it starts.
2. Doesn't seem to run hot but when I shut it off the radiator cap is relieving pressure out the vent hose, not to the point of overheating, maybe bad cap or just because the engine isn't all the way broke in, timing???
