MrJLR
Built, not bought
I see they sell extra long lugs/struts.....
What is the stock oem length....mine measures 1.322.
Jeff
Jeff
Thanks...something ain't adding up....I believe the strut is rectangular, and could be put in either way..... but only fits properly one way. I believe the long sides contact the band and adjuster. I am sure someone else will chime in.
So the lug goes in the short way...right ?If you look at the band strut you will see the short sides have been rounded. The short sides contact the band lug & the adjuster block. It can be a bit fiddly because you have to tension the band (I use a long flat screwdriver) & side the strut in at the same time.
Thanks.....no rush!Give me an hour or so to get home Jeff & I will see if I have any close-up shots of the rear band on my hard drive.
Thank you!Sure Jeff. The lug (strut) goes in the tall way. It is a bit fiddly but it will drop in wehen you compress the band with a long handled screwdriver. I hope you dont have the rear drum fitted, because that would cause the difficulty you are having. Fit the band & strut first, then locate the low reverse drum inside the band to engage with the splines on the sprag inner race. Only machine the drum if the surface is heavily scored, that is the reason for longer struts. This is the only half decent photo I have on my hard drive. Sorry it's a bit fuzzy, but I think you can just make out the orientation of the strut.
Cheers. Gaz
New band doesn’t fit the same as the one that broke.....Here's a silly question.
Why would you have to machine the drum to put it back together the way came apart?
I don't know if mine is stock or not, but my strut is 1.322"That does seem like a tight fit. Just make sure the band doesn't **** over out of centre when you install the drum. I can get you the measurement of a stock sized strut, but I'm back in the shop not before tomorrow.
I just verified that the band is correctly seated in the stationary strut....Yes Sir! The band anchor is ok. Check out the size of the gap between the band ends in my photo & compare it with yours. It looks for all the world as if your lower band lug is not properly engaged in the anchor strut.
They're very similar . ..but when I put them on the drum, the old one clearly fits looser.....How do the diameters of the bands compare when laid on top of each other?
Hmmm.....I wonder if I should just trim the strut down a little bit. ....The old one is probably 40 years older than the new one & has seen a lot of service. Nevertheless the new band must fit unless it was packaged wrong at the manufacturers. Highly unlikely but not impossible. Crap! I wish I was just around the corner from you, I'd be there in a flash!
Jeff
