Jet Plane Smoke Lines in the Sky
dodge freak
Too close to Detroit, lol
Tonight is perfect, hard to photograph all of them with my $80 Canon camera.a
One plane I could see with my eyes was flying in a darken stream in the sky. Must had been another plane just there 20 mins earlier. You would think they fly a bit different not to suck up all that dirty air. By the time I got my camera the plane flew all the way thought it.
I count over 20 jet steams, in the sky. Air must be still up there tonight, its summer, lol
This is just one part of the sky, the other parts didn't come out cause the sun was too bright
Its all water vapor that freezes, nothing dirty about it. as H20 is a byproduct of burned fuel. Our cars would do it too if it were -40...We have Vandenburg AFB up the coast and we see the rocket/missile contrails for 1-2 nights at a late sunset. Very nice to see those, like little stars flying up slowly if you catch a launch in the eve.
Here,let me share a few pics with everyone !!
I had a lady come in to my shop Saturday and tell me all about chemical trails. what a whack job lol
The coolest thing I ever seen or heard was during the air space shut down for one week after 9/11. Was 2--3 days in to it and yep nothing in the sky all day long. One mid afternoon I heard this weird sound while outside and here comes 2 air force jets hauling ***, they went form one end of the sky to the other in a few seconds.
Maybe they were not as high up, 35,000 feet the passenger jets fly at. I think the passanger jets go 500 mph, don't know how fast those fighter jets can go but it seemed like they were going 20,000 mph, lol
6pak, some nice pics there! Where was that last pic taken at?
C
CAREFUL...............you'll get the "chemtrails" conspiracy theorists up in arms again.
Taken E end of Lake Coeur d Alene Sept 6, 08 using old Olympus manual lens, 28mm F2.8, at about F16, adapted to my new Canon 40D
Back in 1999, I saw chemtrails near my work in Alvin, TX. This town is very close to the Johnson Space Center aka NASA. This B-17 was going back and forth in the sky creating parallel lines going east to west over the South Houston area and then it went north to south for another couple of hours. I'm not some conspiracy nut. I saw it. I grew up in the aviation industry and I know alot about aircraft and flight practices and regulations, etc. Their is no reason that any plane should be doing those patterns in the sky for that amount of time leaving a consistent contrail throughout the whole flight. None. I'm not sure that it was chemicals to help us or harm us, but I don't know what it was. The plane was based out of Ellington Field which is NASA's base for flight operations. The JSC has no runways and Ellington is about 10 miles away. So, what do you say about that? (By the way, I have witnesses. About 50 of them from my office.)
Freak alert;
Someone take away his and my post into cyber space.
I KNEW it!! I freekin KNEW it!!!
And just how, O' great chemist, do'ya know these were "chemtrails?"
Has your mind been controlled?
Did all the bugs get cancer?
Has the earth turned rose colored?
Puuuuuuuuuuulllllllllllllllllllllllllllleeeeeeauuuuuuuuuzzzzzzzzzzzzzzzzze
My GF worked at Bonfil's Blood Center in Denver then and they loaded up an executive jet with blood bound for NYC. It was the first private plane airborne after 9/11. She has a picture of it right after takeoff being escorted by two F-16's. They were at 100' when the jet lifted off the runway, one on each wingtip. They escorted them all the way to NYC.
Well a 10 second car can still go 55 mph on the freeways if the driver lays off the gas.
I would guess a great fighter plane could fly slow
Specifications (F-16C Block 30)
Crew: 1
Length: 49 ft 5 in (15.06 m)
Wingspan: 32 ft 8 in (9.96 m)
Height: 16 ft (4.88 m)
Wing area: 300 ft² (27.87 m²)
Airfoil: NACA 64A204 root and tip
Empty weight: 18,900 lb (8,570 kg)
Loaded weight: 26,500 lb (12,000 kg)
Max. takeoff weight: 42,300 lb (19,200 kg)
Powerplant: 1 × F110-GE-100 afterburning turbofan
Dry thrust: 17,155 lbf (76.3 kN)
Thrust with afterburner: 28,600 lbf (127 kN)
Performance
Maximum speed:
At sea level: Mach 1.2 (915 mph, 1,470 km/h)[46]
At altitude: Mach 2+ (1,500 mph, 2,410 km/h[1]) clean configuration
Combat radius: 340 mi (295 nmi, 550 km) on a hi-lo-hi mission with six 1,000 lb (450 kg) bombs
Ferry range: 2,280 NM (2,620 mi, 4,220 km) with drop tanks
Service ceiling: 60,000+ ft (18,000+ m)
Rate of climb: 50,000 ft/min (254 m/s)
Wing loading: 88.3 lb/ft² (431 kg/m²)
Thrust/weight: 1.095
http://en.wikipedia.org/wiki/Genera...ng_Falcon#Specifications_.28F-16C_Block_30.29
F-16 is 26,500 lbs empty, those engines are making the HP but its not called out in HP numbers but thrust, too bad. It likely make 600 HP look like nothing at all
Specs don't show how much fuel is used every minute while at full power
