Johnnycuda's 68 340 4 speed Progress Thread
johnnycuda
JohnnyCuda's 68
Just thought I would start posting stuff I do to the car in one Thread.
Here she is with Poverty caps.... way too high gotta Lower it big time!!!
Uploaded with ImageShack.us
Started changing out the springs to find out I bought ones with the wrong front eye on the spring so I decided to do Lowering blocks instead.
Very nice johnny! if ya have time or any interest to do so, Can you please post anything and everything regarding the 4 speed stuff...linkages, Z-bar, clutch fork...Etc to show how everything goes together. :)
Did door weather strip Today from metro .
Man what a product the clips pushed in easy the fit fantastic.
Much better than any soft seal I remember.
Started the tank install.
Cut the tail pipes cause I could not heat them up enough to take apart.
have to redo the pipes anyway they were run in the way of the tank.
Finally replaced the proform race carb with no choke with an eddy 600 electric choke!!
don't worry that temporary red choke hot wire was replaced and fitted correctly along with the return spring
Getting ready to put the stock rockers back on!
