Leaf Spring info/help?
Wow. This was a great turn out for my first post. Thank you all I really appreciate all of your input. I did make my decision earlier today and went with ESPO. They hooked me up with everything I needed (shackles, bushings and U-bolt). They were really easy to talk to and kinda made it easy for me to just go ahead and make the purchase. Can't wait to get them and put them under the car.
Good price and great people to work with. I really believe you will be happy with your purchase. I certainly was
Those appear to be the same as General Spring, same part # and all.
Could be. Stengel carries Stanley Springs (Harrisburg PA). However, Triangle Spring is another big manufacturer and has similar number system. I forget where they are based but they're not hard to find.
Ever wonder why the passenger tire is the only one to apply power to the ground in a single track rear end??
Doesn't the driveshaft rotate counter-clockwise, thus rotating the differential in that direction, lifting the passenger tire off the ground, and pushing the driver's tire against it?
