nope, he'll need the red. Look at his zip code.
stamped rockers on a shaft or pedestals with no adjustment take hydros. if you got nuts on your rockers, you CAN use solids, but its the cam that dictates them. 95% of 318's use hydros. if your late 318 has a weird skeleton looking thing between the lifters, you need rollers.
..............I have a 75 duster with a factory 360 4 barrel??????????????????
Is he asking about replacement or what style to get for a new cam?
how do i tell what kind of lifter i need for my 318 solid or hydraulic
Not necessarily. You can have hydraulics with adjustable rockers. I do.Pull the valve cover. If the rocker arms are stamped steel and almost as wide as they are long with no adjusting screws on the pushrod end, you have a hydraulic cam and lifters. If the rockers are cast and are sorta skinny with adjusting screws on the pushrod end, you have a solid cam and lifters. Also the end of the pushrod will be a ball on hydraulic and a cup on solids....
Did it come that way from Ma Mopar?
Nope. But we don't know if the OP is working on an unmolested stock engine, or not. ???:???:
