Look what has a new home in time for Christmas.....
DUSTPAN340
Cedar Rapids ,IA
just finished notching the K member and putting the new motor in with intake and some extras...still have to wire it...put in the injectors and MSD box ...new alum radiator...gears...sub frame connectors...etc...but the plan is to have her running in two weeks...:blob:
wayne
If I missed something , Tell us about the engine. Looks sweet
the engine is a 416 built by Muscle Motors
11.1 compression forged flat tops
Eagle H beam rods
Eagle 4'' stroke steel crank
Comp Cams Hydraulic Roller Cam 540/240
Comp Cams Hydraulic Roller Lifters
Comp Cams Roller Rockers
Melling High Volume oil pump
Milodon Deep Oil Pan
Milodon Gear Drive
Eldelbrock RPM Alum Heads...(completely tore apart and redone and ported to match gasket)
Intake is by F&B Throttle Bodies...
EFI SIX PACK...
That is sick....I had to rub my eyes, I thought there was something wrong with the carb set up. They looked so clean and smooth then I relized efi LOL..... very nice
nice very nice
want to know what thar master cylinder is off of if i could
Nice!!! Might want to change that crossover line on there. Go with one that will be tight/straight instead of hanging down. Are you using the MSD E-Curve dizzy?
