Looking For A 904
I have a 65 cable shifted (pushbutton) Im in ct.
Do you need for a 64 or 65? The valve bodies and cables are different. 64 was a pushbutton with 5 detents in the VB. 65 was columm or floor shifter, with 6 detents in the VB. The VB's and cables can be swapped, however. Let me know and I will see what I have, I am in Florida.
Sent you a PM. I have a 65 LA904 trans. I need to know if you are going to use pushbutton shifter, and if you need cables, and which cables. The 64 PB ones, the 65 columm shift, or the 65 floor shift. I can swap the valve body to a 64, if necessay. This trans is a rebuildable core.
