momoparman
MOISMYHOME
I use a socket that's just bigger than the locking lug-nut. Take some 80 grit sandpaper and fold it in half. Wrap it around the nut then pound the socket on over the paper and nut. If you do it right it should be a very tight fit. Once on just use your impact wrench to remove it.
I've done this many times and if the nut isn't siezed onto the threads, it should work for you.
