ANybody tried this Swap? I looked up some specs & it seems that the A & M-Body Boxes are almost identical in appearance & specs.
From another Webpage (http://www.dippy.org/forum2/index.php/topic,244.0.html), it is mentioned that the M-Body Pwr Steering Box has a 16:1 Ratio - Same as that pricey-axxed Firm Feel Manual Box, but for a fraction of the cost (NAPA = $172 + Core - gonna chk RockAuto next).
The only difference that I see is the Output shaft diam is 1/8" bigger on the M-Bod. Maybe this can be overcome by using the M-Body Steering Arm?
So, I once again ask you, the knowledgable ones: Have you made this work?
OR, have you used a box from another model (like a Cordoba, etc) with similar specs & results?
