Woods74
Enlightened Senior
Hi all after much research and obsession, I've got a few questions to ask:
Engine Info/Purpose:
Junkyard '99 5.9 Magnum In good shape, water pump went out but all bearings, cams and pistons in good shape accept one... Broke the ridge between the compression and wiper ring on # 5.
This build will be mild, home ported heads, healthy cam, touch of awesomeness. Into a '74 swinger with 3.55 gears. Would like to keep it out of the machine shop as much as possible.
The BIG Questions:
Pistons:
In intrest of keeping this engine out of the machine shop as much as possible. What is the best course of action on replacing this piston? (set)
Options:
#1 Thought about going and yanking a piston/rod from another junker, that runs a risk...
#2 I've priced stock pistons and they seem to be more costly than if the project went aftermarket...
#3 If we go performance pistons, I've read good things about:
SP H116P
H405P
KB 362
Keeping it about 9.5:1. Milling the head .20 Giving the same effect. KB107 for a little more 10:7:1. Sound about right? Willing to go 89 octane MAX. Whats good here?
If we go the performance/aftermarket piston route, Will The engine have to be re-balanced? And since we're talking machine shop time:
Rods:
How much abuse will the stock rods take? I've read good things about SCAT rods. Whats Advised? Want to keep it budget without cutting throats. What can you get away with?
Thanks for the council. :read2:
The BIG Questions:
Pistons:
Options:
SP H116P
H405P
KB 362
Rods:
