Thinking about trying the borgeson box and magnum manifolds for a turbo build. I havent found anyone that can tell me if the manifold will clear the steering box. I have found people saying it wont work with the power steering pump. That isn't exactly true. If you get the power steering pump and bracket from a v8 magnum jeep and the passenger side jeep exhaust manifold.... It will clear. Obviously you need magnum heads and running magnum accessories. The passenger manifold off the Durango will hit the pump
resevoir. You could always go with a type ii saginaw pump with an external reservoir. Anyway, thinking about giving it a try and if it doesnt work buying some Hedman Tight Tubes and do something similar to turbo66valiant and their 318 build.
