Dartfreak75
Restore it, Dont part it!
What is a whisp? You mean lisp? Haha lmao.I don't know. The fella i talked with had a whisp, kind of hard to understand but he was nice
you'd have to talk to him to understand... a whispWhat is a whisp? You mean lisp? Haha.
I think yellow rose calls him the duck or something like that.. I kind of think that's mean the guys like you said nice and doesn't need any condescending nicknames..you'd have to talk to him to understand... a whisp![]()
well, he got me the answer I needed, so that's what I cared about.. LOL.I think yellow rose calls him the duck or something like that.. I kind of think that's mean the guys like you said nice and doesn't need any condescending nicknames..
LOL...What are your plans for making it Hook? You going to tub it? Home made caltracs? That magnum motor would be fun with nitrous. Probably going to need the nitrous to go tens in the future anyway right?
Getting a truck to hook will be all new to me. I'm sure I'll make some sort of homemade traction device, and a good drag radial. No NOS, if I need it to go 10's I won't go 10's... LOL. May the truck land where it may.... The magnum is what we call the "pass-time-5.9". Something more fun than the 318 2bbl and help us learn/set the truck up for when the 440 is doneWhat are your plans for making it Hook? You going to tub it? Home made caltracs? That magnum motor would be fun with nitrous. Probably going to need the nitrous to go tens in the future anyway right?
You guys may have already came across ”Beetlejuice” they’re out there making it happen. He’s got a few videos on it. Check it out small block on a 100 shot
I was looking at the Tuff country traction bars. I also have some ideas of my own. My goal is to keep the money in the drive train (440/converter) and try to build my own traction devices. Once I get the 5.9 in it, then we should have a traction issue and then we'll go to work on getting it to dead-bite.i cant recall the exact name of it but there used to be a mopar performance kit for the rear axle.
they used it on the rod hall offroad trucks,but we used to put them on the cars as well.
it was an extra shock setup for the 70-s thru 80-s trucks and came with brackets and a shock for each side.
one end gets mounted to the frame and other to the axle.
it helps control the axle windup.
at some point Eberg had it on either the green brick or the duster and had a brief article on it.
or you could ladder bar it,using this simple kit which btw is dirt cheap,but uses heim joint ends.
Tuff Country Traction Bars | SuspensionConnection.com
or make up your own kit,using ideas like this setup which makes this claim
"By using rubber isolated ends we have eliminated the squeaking and binding that can be attributed to heim joint style ends"
DHD 600-657 Super Heavy Duty Duramax Traction Bar Kit (Universal)
LOL.... It will be easier if I end up going C-body 8.75 on top the leafs. That will lower the back like 1500 lbs of fire wood and then the traction device can mimic a Duster's.You might as well make 2 sets....
You could probably sell a set...
He's going to need a welder if he's going to make anyting...use an A-body 8 3/4. That way it fits right up to your leaf springs and make a set of traction bars. Once you lower it you have to change your rear shock degree. The shock locations are to far in to work right..
I think the A-body 8.75 might be too expensive for the budget, and, I question the width vs the truck...… Maybe a C - body 8.75. Much cheaper and very close fit for the truckuse an A-body 8 3/4. That way it fits right up to your leaf springs and make a set of traction bars. Once you lower it you have to change your rear shock degree. The shock locations are to far in to work right..
This is an A-body rear, fits very nice.I think the A-body 8.75 might be too expensive for the budget, and, I question the width vs the truck...… Maybe a C - body 8.75. Much cheaper and very close fit for the truck
Nice. Did you move the perches? The A-body will be too expensive for the build. I'm thinking C-body or E - body. A-body rear ends, in my opinion, are too narrow for a Duster giving it "rabbit tracks". The truck being wider would only amplify that look.
Here is the side look, outside of the wheels are very close to the same. With the wide tireNice. Did you move the perches? The A-body will be too expensive for the build. I'm thinking C-body or E - body. A-body rear ends, in my opinion, are too narrow for a Duster giving it "rabbit tracks". The truck being wider would only amplify that look.
Really deep dished rims, looks nice!. I'd say the A-body rear end in a truck is like a narrowed rear end...Here is the side look, outside of the wheels are very close to the same. With the wide tire
You can use any rear housing. Just have to put on new spring perches and check the back spacing needed to center your tiresI'm also looking at the 71-74 B-body rear ends. Really cheap and about 4" wider than a A-body.
I think I "might" have learned something this morning. I read this morning that the '94-'03 Ram rear ends have the same perch width and are supposed to be a bolt in, but have a wider stance. Maybe a 9.25 with 3.90 gear and sure grip could be had for a 150 bucks??? (I don't care too much for the C clips though...)You can use any rear housing. Just have to put on new spring perches and check the back spacing needed to center your tires
