Mini tub
72duster72
castle rock co.
How much would I gain on mini tubbing a 68 dart. As in tire width and I will not be running a 15 inch rim
Mini-tubbed, and spring relocation, - - 295/55/15 drag radials
I mini tubbed mine and relocated the springs to the frame rails, I am running 325/50/15 on 15 x 10 wleels with a 7 1/8 backspacing.
Op said, "I will NOT NOT be running a 15" rim."
If this means I WILL BE running a 14;
then I see no point cuz what's the biggest 14" street tire you can actually go to the tire-store and put your hands on?
And,
does your combo need more that that?
Should’ve specified I am not running a 15 inch wheel. I’m more in the autocross and drag racing so probably run an 18 maybe a 20 not sure inch wheel. The other question I have is the a body leafspring relocation kit the same as a b body I know I have one, but I’m not sure for what body style
I run a 325/50/15 also. I use to run M/T 28x13.50x15 ET Streets. You should have at least 14" of clearance once you mini tub and move the springs in.
