grassy
To anyone who has been watching our build, you know we have been at it a long time. We thought we would have it completed by end of August but there were just too many road blocks. We are so close but things keep happening..wires, tools breaking and long waits for machine work and parts...and lastly, my health. Such is the life of a restore.
My kid has been a trooper ...not only working by my side but also doing the household work that I cannot do anymore.. as well as keeping up his schooling and participating in sports.
He really wants to hear the engine..we have not started it since we got it in '09 even though we had it broken in last year.
I got this idea while watching Graveyard Carz last night when they started mark's car by shorting out a relay , I think ?
What is the bare minimum that I need done to get her running ?
Where we are at the moment:
Steering column and gauge cluster are not in.
Gas line is in and hooked up.
All running gear is in. Radiator, carb, belts are on. PVC and breather hoses are not on.
I have most of the wiring installed including the wire on the transmission. The trans is in neutral at the moment.
No oil in trans...have to finish running the cooling lines. I assume oil has to be in it.
No water in the rad..I assume that has to be filled with a water / anit freeze combo. Would a surfactant be good ?
I can use the battery out of my RAM.
Installed the dizzy...I am pretty sure the spark wires are on the correct cylinders.
What else do I need to do before I can turn the engine over and hopefuly, it will start ?
Your help is always appreciated.
Ian.
What
Ian.
What
