MrFollmer
Active Member
A few months ago, I upgrade my ‘66 273 intake manifold and carb to an Edelbrock 4bbl set-up. In the process, I decided to change the valve covers to the aluminum black Mopar Performance ones. I installed it all correctly and noticed that the lip on the valve cover was making contact with the intake enough to prevent proper seal. So I did some searching online and realized that a simple modification would solve the problem. I marked the location of each contact point and went to town carefully grinding the lip down flat. I hope it works!
