Mopar Muscle induction Extravaganza Dyno testing SBM intakes, comparison....
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I was really surprised that the Torker
Stayed right with 6 pack manifold
Sometimes more is not better
So, they,re making the SAME POWER.
How could engines with the same power, everything else the same, outrun each other. You have no idea what you're talking about about.
Your answer is flippant.
The Torker has been around before the 6 pack.. Your answer is flippant.
Looking at your msg contributions since 2020 is pitiful.
When did the Torker II come out? You realize it's way different than the old Torker 340, don't you?
Yes Torker 2
Later one
I'd say early 70's
Can't find the original production date on the Torker
I want to say 66-67
Anyone know ??
Edelbrock released the “arachnid” line of intake’s before the Torker with names like scorpion and tarantula. The Torker line didn’t show up until the early seventies.
Six pak on the street will eat your torker, no one has ever done any real street testing in a magazine of six pak vs the rest of you. Six paks rule
I have this and always wanted to try it. Plan was in 2nd and 3rd on street no way street tires would launch from a dead in 1st on the converter.
Figured it 2ould blow the tires. But would be fine with a hit in 2nd
I've got 2 plate kits 50-150 HP I'll be installing on this soon
Be sure to read up on ignition requirements
Reading spark plugs after a test
Ignition timing
Spark plug heat range
A way to retard the timing during blasts
If it's a 50-150 kit I'd say start at 100 hp
MOST IMPORTANTLY MAKE SURE YOU HAVE THE PROPER RING GAP
Traction, get a staged controller
Get a book about Nitrous
Out of curiosity based on your comment would you give a description of your 340 six pack car and what the best time down the track was? I/8th or Quarter mile? Thanks
No it’s not. He told you the truth. I have explained it before on FABO.
He wasn’t flippant. He was factual.
Them remain in the dark why two engines on the same dyno can make the same power and one will beat the **** out of the other.
Got into a discussion about flow benches on FB the other day. No two flow benches are the same. And two heads with the same CFM may not run the same. But time slips don't lie. I've seen a W2 head that flowed 323 CFM on my friends bench make 50 hp than a Brodix head that flowed 337 on the same bench. But people still want to race flow benches and dyno's.
There are guys that purposely never calibrate their flow benches. With a manometer pilot style of bench it gets very tricky because weather affects it hourly. That why I sold my one bench and built an orfice style of bench with electronics. Set it and check it easily with your calibration plates and it doesn’t move. But then again high flow numbers sell more jobs.
There's no fish here
Just for posterity that wish to understand I’ll type it out.
A water brake engine dyno has things it cannot measure because of its very nature. One of those things is transient response. And that is HUGE. And it’s not just a drag race problem. In other words it’s limit in transit response doesn’t just affect drag race engine builds.
Unless you are running at Daytona or Talladega where you almost flat foot it around the track, you will require the engine to rpm (accelerate) from the lowest rpm to the highest rpm and do that over and over and over.
A circle track is nothing more than a drag race between corners. It’s that simple. Just like a drag race.
A water brake dyno (assuming you are doing acceleration testing and not steady state or step testing) controls the rate acceleration while doing the test, usually at a rate set by the operator.
A test by most guys is 300-325 rpm/sec. Larry Meaux has published multiple times several different cars with measured rpm acceleration rates. Off the top of my head I think the highest rate was around 2000 rpm/sec and I think the lowest was about 400 rpm/sec. And that’s during the same run.
So using 300 rpm/sec doesn’t replicate what happens in the car. You can use higher rates than that and 600 rpm/sec is kind of a standard too. If you start accelerating the engine quicker than that, even at a 50 times a second sampling rate you miss too much data. So guys use slower rates for data. It also makes the observed power higher than it would be if you used a higher rate.
So saying all that I want to be clear it doesn’t make the testing useless. Because it’s not. But certain testing covers up things like the engines ability to rpm.
So let’s take the above dyno testing as an example. We have a TRACK TESTED manifold, and a throughly Chrysler tested manifold that both say and I’m paraphrasing here “short branch runner length manifolds” do not perform as good as other manifolds and in the Chrysler book that was referencing either the Strip Dominator or the Offy Port-O-Sonic. It was tested and the Torker was a loser at the track where it counts.
So we either need to stop dyno testing (that would be ignorant) so we need to understand the WHY that makes this so. Again, it the nature of the machine and the testing methods being used.
When the dyno controls the acceleration rates (transient response) you can’t just say manifold A is better than B because it made more power at 300 or 600 or even 1000 rpm/sec.
Luckily I’m old enough to have used this stuff long before I ever used a dyno. I can’t tell you how many times I’ve pulled a Torker or some dual plane intake off a car and dropped a Strip Dominator on it and went quicker and faster. Never once did I have one go slower that was at least built for it. Meaning it’s not built to tow a barge, haul 80,000 pounds or it’s geared to run 200 mph when the engine is making 300 hp.
The short answer is you can NOT make air turn a corner and not pay a price for it. It doesn’t always show up as a power loss because of the nature of the dyno and the testing method. Corners and air are bad. Corners and air with fuel (gasoline) is worse. Corners and methanol is downright horrible.
This shows up in cylinder to cylinder distribution but it doesn’t always show up as a power loss because the dyno is controlling how fast the engine accelerates and not the engine itself.
Were we able to test at higher acceleration rates and still collect all the data then you would see less power from the Torquer or DP intake.
I have dyno tests for IIRC 6 different intakes. Same engine. They were tested on a water brake and an inertia dyno. Both engine dyno’s, not a chassis dyno.
What they learned was the best manifold on the WB dyno was the worst on the inertia dyno. And the best manifold on the inertia dyno was the worst on the WB. And the second best was the second worst etc. from top to bottom they were almost perfectly inverted.
Then they went to the track and tested the intakes. And guess what?? The best WB intake was the slowest and the best inertia dyno was the fastest.
That’s because the inertia dyno did not control the rate the acceleration like the WB dyno does and that is why the seeming anomaly.
This is why if we don’t understand the testing methods and the nature of the tool we use we can be fooled by just the numbers.
The answer is if performance matters then you dyno the engine and then go test and VERIFY the test results. Not just believe the numbers.
Luckily for us, this type of thing has been field tested for decades now.
The guys who struggle with the numbers are the guys who refuse to learn.
The Torker is a bad manifold. They are doorstops for any decent build. Unless you are reliving your salad days.
Yup, same thing just a different tool. It’s almost always an operator error or worse yet an operator fraud.
It’s damn sad that that happens and we both know it does. It makes anyone legitimately testing take a black eye for the lazy and crooked.
The torker family of single plane intakes for big blocks got a real bad rap there for a while, too.
That's also been disproven.
I’d have to look in my book but I don’t think Chrysler said the big block Torker had those issues.
But I’m not 100% sure on that and I don’t have the books here with me.
About 20 years ago, I was at a general car swap meet with very little Mopar stuff. I did find one guy with mostly Mopar stuff, and he had a SBM dual 4 barrel intake manifold. I don't remember the brand, but he was asking $125 for it and probably would have taken $100. I have been kicking myself in the *** for 20 years for not buying that. Even if a good single 4 barrel on a good intake matched the power of two 500 CFM 4 barrels, imagine how cool it would look!
