I am in the process of putting my 340 back together it had a rounded cam lobe. So going through the list of mopar performance cam shafts I chose #p4452761 all of the specs I found online stated a duration @.050 of 228/231 and a 110 centerline. I received the cam today and it didn't have a cam card with it just a generic sheet listing all the cams. The sheet is listing this cam @.050 220/224 and a 108 centerline. Now I'm strongly considering sending the cam back as it is clearly not what it is advertised as. Did opar change the grind and not the info on their site? The biggest reason I chose this cam is the lift and duration because the 340 is getting magnum heads so the lift should increase to .480/.485.
