Can someone help me with the benefits that you get with going to a motor-plate on the front of a engine,Also if you put it in front do you need a mid-plate too or can you use the front motor-plate and the trany mount,Second can you arrive at the same benefit by using sold motor-mounts on the k-frame--Steve
