mrl /mike oiling mod
earthmover
in the tire smoke
nc
will your oli mod work with a hyd. cam ??? i will be using stock rockers ..plan to go to a adjustable rocker later on but not at the time the motor will be done..
400
crane cam 504/528 hyd
comp cam 925 springs
comp locks and retainer
906 heads ported
tm6 intake with 750 (bg) thanks mike mrl
3000 verta and 727 trans
4.56 gear for now
27.5/10.5 qtp to drive on the street or maybe a 28/10.5
70 duster
msd 6 al and mopar dizzy
if your mod will work thats the way i will go on this motor.. just trying to get last min. things before i start to put it together ..only thing left to get is lifters and a few gaskets:D:D
I asked him a little while back if I should do the oil mod with my 383 build (hyd roller) and he replied it would be a good idea...now, I just gotta buy some stuff from him ;)
I have not done it with stock rockers. If I were I would drill and tap the oil feed port from the block to the head and put a restrictor in. There is no way to contain the oil with stock rockers, unlike roller rockers where the oil is somewhat controlled with the rockers and spacers.
got some adjustable rockers on the way... found a great deal on some factory rockers.. :D
