my new project and many thanks tooooo
thanks im trying to move on with my life a little...kinda tough sometime.....got the fuel pump installed front and back glass side glass starting on the door glass..charging studs on push pull switch installed most all the wiring is done except battery box and wiring for that also wiring the shiftnoid gauges will be installed along with shut down switch for oil pressure ...gotta cut the hose ends on the radiator and turn them a little since everything is so tight mount seat chute mount and build wing oil trans fluid and gear oil for the read and should be fire in the holes ....
