This might help somebody make a decision on their project. Only offering my view, take it as unprofessional advice
Tapered bearings offer more surface area and in the 8.75 have been proven for years to be reliable. I like both green and tapered bearings.I will take the tapered bearings any day over the straight roller.
It's getting close to winter.Man, you're chubbier than I pictured you.And I can hardly wait...
Actually I'm over 6 ft tall and have a slimmer build... I always laugh at that picture it makes me look short and fat..Man, you're chubbier than I pictured you.![]()
It may turn into that, but I actually like both styles and have run both without issue. I have zero issue with the factory set up, and zero issue with replacing it all with green bearings if it looks like it ate it's last 2 years at the Crusty Crab LOLGreat, another green vs tapered roller bearing argument thread.
...your right, it isn't a plug....Well what this definitely isn't is a shameless plug for someone's Youboob channel.......
Good stuff, it may help somebody solve their issue.I bought my Duster and found the rear brakes were being soaked by diff fluid. Replaced the brakes as well as the inner seals and readjusted the tapered bearings. Soon found the brakes ruined again. Bought new axles and green bearings from Dr. Diff and upgraded to larger rear drum brakes. The green bearings sealed much better and no more soaked brakes. Had a Duster back in the 80's that kept ruining rear brakes and never could find out why. Same issue, but I did not know then what I know now.
Impact Colours ...... Colour us "GONE"Hemi orange, Green bearings, Purpleshaft cams.. our old Mopars are pretty colorful..
