74 DART'
Looking for some help with my car. Its my 74 Dart- 225 1BBL. Its my daily driver and has been giving me some trouble lately. Seems to run good when its cold outside/ on the way to work, drive roughly 20 miles each way. But on the way home i get caught in a lot of stop and go traffic. The problem im having is the car will stall sometimes i can feel it starving for fuel sometimes it just stalls. Try to restart it turns over but doesn't restart. Pull the air cleaner work the accelator pump sometimes it squirts some times nothing. Grabbed fuel line its very warm and so is filter. Also noticed bubbles rising into clear fuel filter. Thinking maybe fuel is boiling??? is that even possible? Loosened the line from the fuel pump has pressure, ok getting fuel this far, removed fuel filter turn over pumping fuel from line, ok getting fuel to carb maybe float or some other carb issue. Filter seems to be free can blow through it ok. Fill up carb bowl with fuel fires up and makes it home. Has done this same basic scenario three or four times in the past couple months. Ok now some history info, i know i have some trash/rust in the fuel tank sender is pretty rusty and clogs up fuel filter every couple months. Added a extra filter at gas tank- line comes out of sender goes through filter then to pump then through fiter then carb. Replace rubber hose from tank to steel line, also rubber hose from line into fuel pump, replaced fuel pump 1 year ago, added a piece of rubber hose over steel line where it runs over water pump just for a litlle insulation. Running a carter 1bbl but just got a holley 1920 from a member here so will be swapping that soon. If anyone has any ideas please let me know , this is my only ride to work right now so i have to keep it going. Thanks in advance J.R.
